95 Blazer Rear Lift Window and Power Mirrors
I was searching through another thread and it appears there is a relay which will fix my lift window and power mirrors, however the threads all mention an under the hood fuse box which is not there on my 95. I can locate two relays in the glove box and three on the firewall under the hood but none are labeled besides the fuse panel by the drivers door (all the fuses appear good) . Can anyone help me identify the correct relay for the mirrors and windows.
You do not have a relay for these items on a '95. All of these items are powered by the HORN/DM fuse (fuse #2 - 20A).
I checked that fuse and it appears good. All the other things such as the horn still work, just the mirrors and the rear window are not functioning. I checked the lift gate actuator by bypassing the power straight from the battery and it functions. Any other suggestions?
You have to have a wiring problem. There isn't much else that can cause your symptoms.
e602
91
03-08-2015 04:53 PM
RoxStar33
11-26-2012 07:46 AM
fresno99
07-31-2009 08:12 PM
