95 jimmy wobbles side to side on highway...
Old 03-04-2012, 04:35 PM
schollianmj's Avatar
schollianmj is on a distinguished road
Default 95 jimmy wobbles side to side on highway...
so lately I have noticed that my 95 4dr 4x4 jimmy has a nasty wobble or rocking motion to it when I hit a bump in the road. it is bad to the p9oint that I have to take my foot off the gas sometimes to get it to settle down. Im thinking sway bar endlinks or shocks... I havent crawled under it yet as i have been busy with work the last few weeks, but plan on it tomorrow.
any one have any other ideas tha i should look at?
Old 03-04-2012, 08:51 PM
andrewhere7's Avatar
andrewhere7 is an unknown quantity at this point
Default rock & try not to roll
your on track probably a swaybar issue or bad shock, but if all seems good check to see if you threw a ballance weight off a tire, or rear drive shaft, then check front drive axels towit cv joints you should find it in one of these good hunting
Old 03-05-2012, 05:29 AM
step66's Avatar
When I had this problem it was a combination of idler arm,pitman arm,shocks and stabalizer link bushings. Good luck
Old 03-05-2012, 05:47 AM
pettyfog's Avatar
You're on track. Check both front and rear
Old 03-05-2012, 06:38 AM
Idler pitman and front hubs were changed out in november....
as to shocks and swaybar, I will hopefully be under it in about two hours.
Old 03-05-2012, 09:54 AM
appliancguy's Avatar
appliancguy is on a distinguished road
When I got my 99 4 door it had 30" tires on it and it was scary to drive on the hwy. Any bump made it bonce around. I put 225 on it and then had a quiet smooth ride.
Old 03-05-2012, 10:10 AM
pettyfog's Avatar
That's a good point. Not the size, the tires. I've had bad tire do the same thing.
Old 03-05-2012, 10:43 AM
well the snowing just stopped, now the driveway is soaked... so I still haven't been under her. but as to the tires they are factory sized and fairly new. Im hoping for the shock/swaybar as these are cheaper than new tires... but definitely thanks for the ideas.
Edit, crowled under her for a min... lots of corrosion on the old shocks and it looks like oil on one of the housings... not sure what kind they are since there is THAT MUCH corrosion...
I look at it and think, "Damn thats bad." and then remind myself that it is a 1000 dollar truck with 150000 on it adn still runs pretty dam good.
I noticed that at advanced auto i can get Monroe sensatracs for 30 each... even though Im sure there are way better out there, I might get a pair tomorrow and toss them on. i have all the bolts soaking in PB Blaster right now.
Old 03-05-2012, 06:22 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Nice detailed pics ! I would think those stopped functioning as shock absorbers for awhile now - pull one off and see if it rebounds when pushed down or stays collapsed (dead)
Old 03-05-2012, 06:29 PM
pettyfog's Avatar
Hah.. the gas will be long gone on those. \
The point is does it resist when you push it down. my guess is one does not.
Quick Reply: 95 jimmy wobbles side to side on highway...
