95 SES light need info
Old 02-10-2006, 03:25 PM
awalls's Avatar
awalls is an unknown quantity at this point
Default 95 SES light need info
So I have a 95 4.3 and i keep gitting the multiple misfire code. So i changed the dis cap because #3 looked discolored. The plug wire for #3 had corrosion. I did not have time to get new plugs and wires at the time so i just scraped off the corrosion and put it back on. My question is, would scraping of the corrosion work, do i need new wires and if the wire on #3 looke dbad can i assume the #3 spark plug is bad? Also is there any thing else that could bring up the p0300 code? like vacume lines. If it helps I had a egr valve code a while ago but i cleaned it out and put it back in. Now i just get the p0300 code[:@]. Thanks for your help.
Old 02-13-2006, 04:07 PM
Hanr3's Avatar
Default RE: 95 SES light need info
Still haveing problems?
Old 02-14-2006, 03:28 AM
awalls's Avatar
Yeah im still having issues. I put new plugs and wires in but im still getting the p0300 code. Could use some help on this one. Thanks.
parks336
12-01-2023 12:34 PM
zedartwo
02-04-2010 02:30 PM
93blazerman
05-05-2006 03:36 PM
blazinloud
Engine & Internal
05-01-2006 02:53 AM
bongabilla
03-16-2006 09:36 PM
Quick Reply: 95 SES light need info
