96 Blazer Code P0302 and flashing
Old 10-23-2010, 10:10 PM
betron02's Avatar
betron02 is on a distinguished road
Default 96 Blazer Code P0302 and flashing
Hi there guys new guy here, I have a quick question my friends truck a 1996 Blazer with 90k rounds on it just gave me a code P0302 misfire on cylinder #2. Also when the you drive the truck the service engine soon indicator flashes several times while driving. She has not changed the spark plugs since she got the truck 50k miles ago and the truck still has the stock distributor cap and wires. I'm guessing its either a wire or the cap or maybe a spark plug. Any other suggestions on what might be causing the issue. I have to fix her truck soon otherwise she is going to kill me
Old 10-23-2010, 11:40 PM
Sparky's Avatar
Sparky is an unknown quantity at this point
Sounds like you're on the right track. #2 Plug, Wire, or Distributor Cap. The cap contacts are probably burnt badly and the wires are suspect too. The light flashes because it doesn't miss all the time. Sounds like it's time to replace all plugs, wires, cap, and rotor button. That should make it last another 90,000. :-)
Old 10-24-2010, 10:59 AM
betron02's Avatar
Thanks man BTW the cables are expensive but they are better than the factory ones.
Old 10-24-2010, 11:09 AM
98HeavyChevy's Avatar
98HeavyChevy is on a distinguished road
Sounds like it is the #2 plug or wire as suggested above. I also read that a malfunctioning MAF can cause the same code. This was the code I had after a minor tuneup and stripping that socket. I just cleaned it out (might have had remnants in there from the tap) and while I was under the hood I cleaned the MAF for good measure.
Long story short. If the tuneup don't help check the MAF.
Old 10-24-2010, 02:06 PM
betron02's Avatar
The truck a new MAF, I replaced the Cap and rotor and wires problem went away but it came back about 5 hours later, I didn't had a chance to change the spark plugs.
Old 10-26-2010, 10:31 AM
Looks like you already know what to do then. The plugs suck to change on this beast. Best of luck. lol.
JeromeyS
17
01-14-2015 05:51 PM
Blazeme
05-18-2014 12:03 AM
ezblazer
05-19-2013 07:42 PM
Queenpin
03-05-2010 03:56 PM
MRDCSE
02-18-2007 11:51 AM
Quick Reply: 96 Blazer Code P0302 and flashing
