96 Blazer Ignition Control Module removal
I have 96 blazer 4.3l 4wd. It has been running pretty rough and threw out a P0340 code. So I went to replace the Ignition Control Module (camshaft position sensor) in the distributor. Got the cap off, got the rotor off and removed the two screws that hold the module. The problem is I can't get the module out past the metal shield that sits under the rotor. How do get this shield and/or module out. Generally I can figure things out but this one has me stumped. Any help would be greatly appreciated.
I believe I have found the answer to question:
Okay, I looked at my 96 factory manual. GM calls the pickup coil a hall switch. You have two options. One pull the distributor or turn it over (cranking or turning with a large socket at the crank pulley). The vane wheel must aligned with the hall switch for removal. GM manual reads:
6. Hall effect switch: The square cut hole (C) in the vane wheel must be aligned with the hall effect switch in order to remove the hall effect switch (Figure 4).
So looking at the vane wheel, the cut slot (on the edge) must be directly over the switch so it can come up.
Thank you to any who tried to find a solution.
Guest
Posts: n/a
No actually, thank you, never would have gotten it.
This is a good write up on this code, also I understand you need to have a case re-learn done by someone with a tech 2 scan tool.
Part 1 -How to Test the Cam Sensor Diagnostic Trouble Codes: P0340, P0341=
Crankshaft position sensor relearn, (AKA case relearn), does not need to be done when replacing the camshaft position sensor. It is recommended, not required, to check and adjust camshaft retard. That must be done with a capable scan tool, (not necessarily a Tech2).
Brian5792
10-24-2018 11:34 AM
nortonii
07-10-2011 03:09 PM
cannibal440
Performance & Brainstorming
03-18-2008 10:47 AM
USMaverick101
10-31-2006 03:10 AM
USMaverick101
10-29-2006 10:29 AM
