96 Blazer Rear Drum Backing Plate -- No Longer Available?
Hello everyone,
I need to replace the backing plate for the Rear Drums of my 96 Blazer. It looks like the part has been discontinued by GM and there is none available in the Aftermarket...Really? I can't believe that an essential component of the Drum Braking System is no longer available. I've checked Autozone, RockAuto, LMC Truck, NAPA....nobody sells it.
I guess I'll have to go to a junkyard....anyone else have any ideas or had to replace a Drum Backing Plate recently? My truck has 260,000 miles and the drums are periodically sticking. I have replaced every other component and I now think the backing plates are worn such that the shoes are not sliding right.
Any ideas on where to buy these parts?
Thanks!
Thanks!
I am not sure if a 91 backing plate is the same as a 96 but LMC Truck has them for the 91. I was on another forum for the same issue and a comment was made that 85 to 97 uses the same backing plated. A local GM dealer should be able to confirm what years are compatible.
Truck Parts and Truck Accessories
Here is a possibility:
The backing plates are designed to use #514 shoes, which GM has used since the mid 70's. They are also used on your 96 Blazer. There are two different backing plates: The only difference is the way the wheel cylinder mounts to the backing plate. The early ones used a clip:
Dorman - Help Left or Right Rear Backing Plate with Drum Brakes 13867: Shop our selection of Brake parts at Advance Auto Parts
and the later ones were bolted on, like yours are. Either style will work, but you will need to change your wheel cylinders to the clip style instead of bolting on. Tru-Torque Drum Brake Wheel Cylinder W37625: Choose the best Brake Wheel Cylinder at Advance Auto Parts
I haven't seen the bolt on style backing plates available for quite a while. Somebody probably has them, the question is where.
mattkellers
07-05-2011 06:58 PM
spikell
10-13-2008 10:20 PM
