97 Blazer oil cooler bypass
Old 02-14-2015, 04:30 PM
Damato's Avatar
Damato is on a distinguished road
Default 97 Blazer oil cooler bypass
Has anyone used the GM 14081300 adapter to mount oil filter back onto block in a 4.3. How does the oil bypass if the filter plugs? Thanks
Old 02-14-2015, 06:19 PM
Worx's Avatar
Banned
Worx is on a distinguished road
I do this to all my 4.3s,if you change the filter when you should you dont have to worry about it plugging up.
Old 02-14-2015, 06:25 PM
If you're going this route, you might want to replace the "pressure regulating valve" (GM calls it oil pump bypass valve). The valve is in plain sight when you remove the adapter. If/when the spring gets weak or breaks, oil pressure takes a dive. Cheap part, under $15 at the dealer. Here is a "typical" illustration of how the bypass system works:
LesMyer
06-15-2015 10:29 AM
litterbox99
01-03-2015 09:33 AM
fslobodecki@yahoo.com
04-15-2011 03:29 PM
Duntov
03-29-2008 10:16 PM
Jetfixer
07-11-2006 05:02 AM
Quick Reply: 97 Blazer oil cooler bypass
