98 blazer headlight problem...i think
Old 01-28-2010, 03:56 AM
chevymobbin's Avatar
chevymobbin is on a distinguished road
Default 98 blazer headlight problem...i think
First off hi Im marcus and new to the forum. im from norcal... now on to my prob...
so.. i have some projector headlights on the way and before i install them i wanna fix my headlight issue.
basically my headlights never turn off nor can i adjust whether or not my DRLs are on.
the only time they shut off is if i apply my E brake and then turn off n turn on the truck. i read that my car is equipped with a light sensor and they should come on automatically so is that sensor broken? if so is there a bypass method. i have halo projectors coming and i want to be able to enjoy them not have the projectors constantly on.
thanks in advance
Old 01-28-2010, 04:27 AM
awe341's Avatar
awe341 is on a distinguished road
It sounds as though your relay for your daytime running lights may be bad. You can try replacing the DRL relay located in the under hood fusebox and see if that solves your problem.
If the problem continues with a new relay and you don't mind not having the daytime running lights, you can simply remove the relay entirely and your lights will only operate with the dash switch.
Old 01-28-2010, 01:11 PM
y didnt i think of that... il just remove the relay then
TiaRC
08-31-2014 07:18 PM
dtslammer
04-16-2009 02:37 PM
butters
02-07-2009 10:59 AM
Royawest
12-09-2008 06:24 PM
nine5blazer
10-18-2005 05:19 AM
Quick Reply: 98 blazer headlight problem...i think
