98 Blazer misfire issue
Old 04-06-2010, 09:51 PM
dutchs98blazermarkIII's Avatar
dutchs98blazermarkIII is on a distinguished road
Default Finally running the way its supposed to
So upon getting everything else together, all the sensors hooked back up we turned the key and she started right up, then i heard a weird sound... started sounding like metal expanding, so i looked under the truck to find the catalytic converter building up with pressure inside to the point that it was expanding rapidly. I grabbed a drill real quick and before i could get the bit all the way in it had so much pressure that it blew the bit out. so then i drilled more holes and low and behold she runs perfect now, just sounds like a hurricane coming down the road. one big battle over....my wife better appreciate all the work i have put in to this ****ing truck. Now to fix the small things and she will be rolling down the road in a matter of days.
Old 03-06-2018, 11:52 AM
Shaun Johnson's Avatar
Shaun Johnson is on a distinguished road
Default 98 blazer wont go over low rpm
Wont go over 30 or so bud id put money on it that your cam sensor has failed and it will start in lymph mode i had a chrysler sebring did exact same thing ran perfect til 2000 rpm then seemed like would die out replace all kinda stuff last thing i changed was the cam sensor fixed it instantly
jmatt07
12-18-2009 09:48 AM
cdonofrio13
08-10-2008 07:06 AM
Mustgofaster
01-11-2008 10:36 PM
gus
04-04-2007 07:42 PM
Quick Reply: 98 Blazer misfire issue
