S10 Zr2 won't go over 40
Old 05-08-2017, 08:36 PM
TobiasTheBoss53s's Avatar
TobiasTheBoss53s is on a distinguished road
Angry S10 Zr2 won't go over 40
I have a 1997 ZR2 S10 manual reg cab with the 4.3, and it's running horribly. When I start it up, it sounds fine, but as soon as I go over 5 miles per hour, it gets all choppy, won't go over 10 in first, and won't go over 45 in 5th. The engine light flashes at me. then, I pull it to the side, turn it off and then back on again, and it runs like normal. I have no clue what's going on. I replaced the MAF, spark plugs, spark plug wires, cap, rotor, and O2 sensor 1 and 2. Still runs awful. Any suggestions before I drive it into a lake?
Old 05-08-2017, 09:15 PM
Strangerock's Avatar
Strangerock is on a distinguished road
I have heard of a plugged catalytic converter having symptoms like this. Do you get a code with that engine light?
Old 05-08-2017, 09:16 PM
Really? Thankyou
Old 05-08-2017, 09:33 PM
I haven't heard of a catalytic converter causing that many problems but I shall look into it.
I think it would smell of eggs or make a whistling sound if its clogged. Maybe its the fact that my exhaust was chopped after the cat
Old 05-08-2017, 11:38 PM
Private_Ops's Avatar
Private_Ops is an unknown quantity at this point
Did you have it checked for codes?
Old 05-09-2017, 06:41 AM
Ya like twice a month. I havent scanned it since I replaced my cap and rotor but I'll check. I have unlimited access to a tech two
Old 05-10-2017, 09:33 AM
Tajohns34's Avatar
What are the codes?
Phandango
11-22-2019 07:22 AM
1998mom
07-30-2013 12:03 AM
amp042
06-09-2013 04:29 AM
deekisses
05-17-2012 11:31 AM
Quick Reply: S10 Zr2 won't go over 40
