Abs/Brake light on when starting truck. Move truck. Turn off/on no abs/brake.
Old 05-23-2017, 08:49 PM
ussexplorer's Avatar
ussexplorer is on a distinguished road
Default Abs/Brake light on when starting truck. Move truck. Turn off/on no abs/brake.
2001 s10 blazer.
Start truck up and sometimes I have a abs / brake light on. I check the ground and connectors. Seems to be okay. Same thing with brake fluid. If I drive the truck a few feet and turn it off. When I restart the lights are off. I have actually just turned the truck off. Pushed it back and forth while in park. Turned truck back on. No lights. If I don't move the truck at all. The light will keep coming back on most of the time. I'm thinking dirty or bad spot on a abs sensor. Oh and once the lights are on. They stay on and once they are off and I drive around. The only other time I had this issue was on my grand prix and it just got worse over night and just ended up being a bad sensor. Any additional testing before taking it to the shop to have it scanned or should I just take it in when The light are on and see if they can scan it?
Thanks,
Josh
Old 05-24-2017, 06:00 AM
FMB42's Avatar
FMB42 is on a distinguished road
The ABS sensor wires are prone to failure after time. Road dirt and/or salt can also foul these sensors. Some people have had hit-or-miss luck with cleaning the sensor areas, while others have the same luck with replacing the sensors w/o prior scanning. However, the safest thing is to have the system scanned and repaired as needed.
Charder
12-08-2013 08:30 PM
smokii
10-18-2012 07:23 AM
Tim5580
03-19-2012 03:51 AM
Hollywoodsnake
09-12-2010 03:34 PM
Deezy
10-25-2007 08:58 PM
Quick Reply: Abs/Brake light on when starting truck. Move truck. Turn off/on no abs/brake.
