ABS problem 2003
Old 02-20-2010, 07:54 PM
buckwheato's Avatar
buckwheato is on a distinguished road
Default ABS problem 2003
2003 Blazer 4x4
My abs is kicking in when it shouldn't. It sounds like the left front wheel.
This happens even at very slow stops...but only sometimes.
Anybody got any ideas?
Thanks, Bob
Old 02-20-2010, 11:04 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Problem with the wheel speed sensor possibly.
Old 09-26-2013, 05:19 PM
billfond's Avatar
billfond is on a distinguished road
can any 1 tell me when checking the abs sensor what is the resistance reading should I get, I know O.L is open loop replace, would like something around .08 be ideal .Thanks Billy.
Old 09-26-2013, 06:26 PM
rexazz2's Avatar
often when the bearing is starting to fail it will take out the ABS sensor
If you can find an open area to weave on the road at about 50mph
you will usually hear the bearing growl that is going
If you steer to the left and you hear noise its a right bearing and vice a versa
Old 09-26-2013, 06:51 PM
Resistance is not what you're looking for, AC voltage output is what you need to check: http://ww2.justanswer.com/uploads/GM...s_bulletin.pdf
There is an inner and an outer set of ball bearings in each hub. A worn bearing will be noisy when it's loaded. When turning, one set of bearings in each hub is loaded and the other set is unloaded. Turn the opposite direction and the load transfers to the opposite set in each hub. Using a stethoscope is the best way to determine which hub is noisy.
Tinted
03-15-2012 02:56 PM
iamchevyman5
02-28-2011 04:35 PM
mikepro
01-19-2010 07:27 PM
stormshadow1
04-23-2009 09:46 AM
abe001
11-14-2006 12:07 PM
Quick Reply: ABS problem 2003
