Ac delco original part # 25176789 Or superceeded part # 19177220 updated part?
When you install the new pigtail, solder it to the vehicle harness using rosin core solder and use heat shrink tubing for insulation. DO NOT use the cheezy crimp connectors that come with the new pump. Crimp connectors should never be used on a vehicle.
Here's the lock ring, you might not need it but it's best to have it handy in case you do: Buy Airtex Fuel Pump Lock Ring LR3002 at Advance Auto Parts_____
As mentioned, lube the O ring before installing the pump into the tank to keep it from rolling. If it doesn't seal properly you'll get EVAP DTC's.
If you dont feel you can comfortably solder the connections, then use silicon lube filled twist connectors, avail at any Lowes or home depot. Dont forget to stagger the splices so they arent all in one big clump
I have a writeup on my own fuel pump saga, here.
Including what to look out for and how to fix what you screw up
https://blazerforum.com/forum/2nd-ge...s-fixed-63397/
My local dealer sold me the proper ring for plastic tank for $26
NO local stores NAPA, Adv, AZ, OReilly's had em. NAPA did at whse for next day.
StarBlazing
09-27-2014 11:27 AM
Dadatone
08-24-2012 09:10 PM
2000Jimmy
01-29-2011 06:40 PM
