AC / Heat blower problem (not resistor)
Old May 3, 2010 | 04:38 PM
tcheche's Avatar
tcheche is on a distinguished road
Default AC / Heat blower problem (not resistor)
2000 Blazer, Blower only blows on 2 and 3, and not as hard as it probably should. On 1 and 4, it doesn't blow at all. I have changed the blower motor resistor and checked all of the fuses. Any other suggestions?
Old May 3, 2010 | 04:41 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
im thinking a bad switch
Old May 3, 2010 | 04:44 PM
tcheche's Avatar
Where would I find the switch? And is it as easy to replace as the Resistor?
Old May 3, 2010 | 07:41 PM
the switch is what you turn to select a fan speed, its on the dashboard right under the radio
Old May 3, 2010 | 08:09 PM
The resistor pack is the most probable cause for the condition. Does it work on high? High is separate from the resistor and is run by a relay.
Old May 4, 2010 | 05:58 AM
tcheche's Avatar
Definitely not the resistor. I switched it out with a brand new one, and that didn't fix the problem. Next item is the switch. What is that switch called? I want to be sure that I purchase the correct part.
Old May 4, 2010 | 08:50 AM
It is the part of the HVAC control module, but it looks like there may be an AC Delco listing for just the switch itself.
Before you go that route, you may want to test the switch with a multimeter. From your description of the problem, it sounds like you have the manual HVAC controls (ie no auto modes). If that is the case, then here is the wiring diagram for your blower motor and its controls:
Attached Thumbnails AC / Heat blower problem (not resistor)-hvac_sch.gif
Old Oct 10, 2010 | 01:33 PM
streetbob's Avatar
streetbob is on a distinguished road
Default Blower relay
Thanks swartlkk! I'm a new member and was just browsing the tech section when I found this thread. For about 8 months I have had a problem with my blower fan not running at all when I switched it to high. I replaced the fan speed switch but that didn't fix it. So when I read your post about the High fan controlled by a relay, I thought "Woot! thats probably it!". Ran out and got the relay and the fan works on high now. Thanks very much!
Old Jun 19, 2012 | 12:01 PM
filmoz's Avatar
filmoz is on a distinguished road
Please can you tell me the location of the relay that controls the fans highest speed as I am having trouble locating it
thanks
Old Jun 19, 2012 | 12:05 PM
thanks
Other than what is stated in the wiring diagram which is applicable for the 98+ trucks, I cannot. Sorry. You have not supplied enough information.
