Adhesive for door panel plastic
Old 04-11-2017, 06:35 AM
Graveyard's Avatar
Graveyard is on a distinguished road
Default Adhesive for door panel plastic
Morning All,
Just wondered if anyone can recommend a good adhesive for the plastic to plastic areas. Mainly my little troughs in the bottom. I'd like to glue the bottom inside corner while I have the panels off. Even a black or grey putty type if that's all that available. I've tried super glue on speaker cover tabs on the dash but it doesn't work at all.
Thanks and have a nice day
Graveyard
Old 04-11-2017, 07:17 AM
Rusty Nuts's Avatar
I've always had the best luck with JB weld. Just make sure the surface is clean.
Old 04-11-2017, 04:50 PM
Graveyard's Avatar
Okay, Thank you.
I tried "Dr. Bond" by permatex. So far so good. Not sure it will hold up over the long run though. Only time will tell.
Later
Old 04-25-2017, 03:00 PM
cmockensturm's Avatar
cmockensturm is on a distinguished road
3M VHB tape. It will hold up to vibration, bumps, and high temperatures.
Old 04-26-2017, 06:46 PM
Chris82's Avatar
Chris82 is on a distinguished road
I am thinking about giving that Q Bond a try that Eric the Car Guy has shown in a few of his videos.
Old 04-26-2017, 07:54 PM
Graveyard's Avatar
I've decided not much of anything glue related is going to hold for long. Once the tabs break it's probably tine for a new door panel. Some of the glue is still holding up but to help me forget about it and reduce any rattles, I lined the bottoms with a rubber backed black carpet. Actually trimmed them from an old company mat. Works great!
Later and thanks for the input
Old 04-27-2017, 01:14 PM
Chris82's Avatar
I wish there was somewhere to get a "new" door panel instead of a new to you brittle plastic door panel. If there is, let me know because all the salvage yards around here are running out of Blazers, Jimmy's, S-10's... and the ones they have, well the panels are typically destroyed.
Old 05-05-2017, 07:46 AM
Gater's Avatar
Gater is on a distinguished road
Lemme know (or toss a pic up) of what you are looking for. I've spent many an hour looking for parts for my 04 blazer (interior mostly). I've found factory replacement pieces for pretty reasonable online, can share or help "innovate" a solution as I've had to do for some things.
oneluckymann
08-22-2016 02:06 PM
RED21
05-07-2013 11:40 PM
richphotos
09-11-2012 11:15 AM
babeba67
09-15-2011 02:13 PM
ABN31B
04-11-2009 09:09 PM
Quick Reply: Adhesive for door panel plastic
