After a plugs cap & rotor change, not starting up. Plz Help!!
Old 02-11-2007, 04:06 PM
kerander's Avatar
kerander is an unknown quantity at this point
Default After a plugs cap & rotor change, not starting up. Plz Help!!
Previously my 95 blazerwould start right up. Now at 100k miles, I changed the plugs,cap and rotor. It had autolites in it, but now has rapidfires. It will crank but just won't start up. I thought maybe some moisture gotin the cap so took it off and WD40'd it good then dried it out with a hairdryer. Could over tightening the plugs do it? I really need this car for a drive to a class tonight! [&:]Any ideas would be greatly appreciated.
I checked the plug to cap wire order, plug connectors to both the plugs and the cap, battery, alternator, and tried jumping it. There's a small hose coming out from the plenum on the back that's kinda loose, so I tightened it on and tried it, then took it all the way off and tried it. Nothing.
Would taking off the rotor and drying it out possibly help? I didn't think it got wet at all before I put it on, but I've got no ideas now.
Old 02-11-2007, 06:53 PM
kerander's Avatar
Default RE: After a plugs cap & rotor change, not starting up. Plz Help!!
Ok, there was a loose connector to theback of the ignition coil. I took it off for something, but then apparently didn't put it on again snug. However, it seems like there is only one connector where on the IC there seems to be a second harness attachable. Is there supposed to be two connectors going to the IC below the male terminal lead (to the cap)? The one that's on there now fits on the passenger side half.
JPinCanada
02-27-2011 01:00 PM
r6thor
01-05-2011 11:36 AM
dirtbagger
02-25-2009 07:51 AM
luke2004
15
08-08-2008 10:49 AM
blazinblack
Performance & Brainstorming
01-28-2008 03:36 PM
Quick Reply: After a plugs cap & rotor change, not starting up. Plz Help!!
