Airflow control is not working
Message you for help
I have the same problem. Can we message and you tell me how you replaced the lines? I am new to my Blazer and pretty uninformed.
1996 hvac vacuum routing
1996 blazer. HVAC was stuck on defroster mode. All actuators were connected. I located the main vacuum line coming in behind the dashboard was disconnected where it transitions from the black line to the gray line that goes to the control ****. I cut a square a hole out of the left side of the glove box to get a better look inside. I could not determine where the gray line connected it had a right angle connector on the end of it. I made a smoke machine from a video I watched on YouTube and I was able to find The line that came from the firewall going across the inside of the passenger compartment deep inside the dashboard. It was in a bundle of wires pretty much straight in and towards the top of where I could see through the hole in a glove box.. The Smoke machine helped me locate the The disconnected small diameter vacuum line that came from the engine compartment. I hope this helps somebody. The homemade Smoke maker was a very cheap tool to make and it worked very well at locating where the vacuum leak was.
Blower motor, fan control and temperature is working but air will come primarily from the instrument panel
2001Blazer4x4
12-03-2005 04:17 PM
