another chevy door pin problem
Old 02-16-2013, 11:17 AM
evuldrporkchop's Avatar
evuldrporkchop is on a distinguished road
Default another chevy door pin problem
I'm hoping someone else has had this scenario.
My wife's truck became my obsession .. she has had this truck for years before we even met. She didn't maintenance it properly and ignored problems that could have saved me these headaches.
Whats the most economical way of redoing a cracked door hinge.. the hinge is cracked where the pin and bushing sits.. it hasn't stretched out also the door latch and lock is bent and broken.
the truck is a 97 blazer 4x4 (red with trim)
am i better off replacing the entire door and getting it matched to the paint (painting it myself or a shop)
or.
am i better off getting a new hinge welded on . replacing lock and latch?
Old 02-16-2013, 11:19 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
You should have posted this in the paint/body section.
That being said.
It all depends, You could get lucky and find a door that matches the paint color. I would search for a door in your color first. Then go from there.
Old 02-16-2013, 11:22 AM
my apologies i am new to this forum.. finally figured out how to post a thread. figured it was time seeing as all the work I have done to this thing.
Old 02-16-2013, 11:28 AM
richphotos's Avatar
But, red is a pretty common color, I would check around at pull it yards, craigslist ect for a door.
Old 02-17-2013, 12:31 AM
abig84's Avatar
if its the hinge on the door side, speaking from experience, just replace the door. those hinges (if they are like the fullsized trucks) are spot welded on and a friggin hassle. they give you little dimples of where to drill the spot welds out but only half were where they were supposed to be and ended up having to guess where the others were, spent like 3 hours just drilling the hinges off.
Old 02-17-2013, 12:56 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
Old 02-17-2013, 06:03 PM
salvage yard and replacing the whole door is probably the best option my wife is just gonna have to accept that i won't allow her to have an unsafe door just for the color of the paint.
Old 03-30-2013, 09:01 PM
habafab's Avatar
habafab is on a distinguished road
weld the crack and the whole where the pin sits solid, then drill new hole for the pin with 1/2 inch bit , i did that on my truck and has worked like a charm ever since
gclaypool62
03-22-2012 07:51 AM
TouringMike
09-22-2011 09:22 PM
coupedeville59
09-02-2010 01:48 AM
portcqb
09-21-2009 05:36 PM
conehead
05-22-2009 07:16 PM
Quick Reply: another chevy door pin problem
