Axle nut torque
Old 08-22-2009, 12:17 PM
Iceman_19's Avatar
Iceman_19 is on a distinguished road
Default Axle nut torque
Anyone know what the torque specs are for the front axle nut? Also the bolts for the front wheel bearing?
Old 08-22-2009, 04:26 PM
I believe it is posted in the front wheel bearing replacement How-To found in the Tech Article (DIY) section.
Old 08-25-2009, 07:25 PM
Iceman_19's Avatar
Unfortunately its not in that thread. I need the torque spec ASAP!
Old 08-25-2009, 07:33 PM
Searched for "axle nut torque" and found it. For your convenience, it is 103ftlbs (130Nm).
Old 08-25-2009, 08:48 PM
Iceman_19's Avatar
My research showed its 180lbs-ft.
Old 08-26-2009, 08:08 AM
Straight from my 1997 Factory Service Manual - 103FTLBS (130Nm)
I assumed it would be the same for 1996... I'll have to check that out.
Old 08-26-2009, 01:15 PM
Iceman_19's Avatar
Hmm, weird. Thanks.
Old 08-28-2009, 02:33 AM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Alldata says 180 also
Old 08-28-2009, 02:55 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
for a 96 its 180
97-03 is 103
Old 08-28-2009, 05:56 PM
Originally Posted by packofqtips
for a 96 its 180
97-03 is 103
You are correct. I have a 1997 and 2000 FSM... Figured that 1996 would be the same as 1997...
95-96 = 133ftlbs (180Nm)
97+ = 103ftlbs (140Nm)
Quick Reply: Axle nut torque
