basic brakes question
Saw something hanging from the rear wheel and it turns out it's some sort of shield that covers the inside of the disc brake rotor. The shield is mostly gone from corrosion. What purpose does this serve? Do I need to do anything, such as replace that piece? Thanks
Keeps the trash out of the brakes. Just replaced mine, only $37.00 NAPA (I figure they might have $3.00 invested in the materials and stamping. Then you have to remove the clips from the rearend to get the axles out. Fun!!!
Sand guards. Probably not an issue so much with hydraulic brakes, but they're a real PiTA with air brake vehicles.... they're bad for keeping heat trapped in and making it more difficult for the brakes to cool down. You don't need it, and I sure as hell wouldn't go through the hassle described above for the sake of keeping it.
Grumbum
02-10-2011 10:32 PM
