Bearing, caliper ?
Bearing, caliper ?
I put new rotors and pads on front end of my 98 4wd blazer.
Just recently i have been hearing a scraping when turning right and when applying brake. Its just the left side. Yesterday i felt a more pronounced grinding feel.
I just pulled the caliper and rotor, all snooth still. Tried to check thehub for play but felt nothing.
Any advice will help, thank you.
Thanks, so if i dont feel a wiggle holdind the studs could the bearing still be bad?
If i am taking it off may as well replce both sides.
I certainly agree with Tajohns to go with a top quality hub bearing such as Moog's top brand. I don't see replacing both unless both are bad or you can't tell for sure which one is bad. Sometimes that is difficult to do. IOW I am saying replace the one that is broken.
Thanks, the noise is definately from the left side. I will change that hub this week.
I just hope that is the problem. The abs was acting up on that side also which i read can be caused by a bad bearing.
