Believe I need to replace the Spider, can someone double check me?
Ok, I have a 95 Blazer, 4.3 with 3 button 4wd, 212,000. Needed a lot of work when I got it. I have replaced the starter, alternator, O2 sensor, plugs, wires, cap, and rotor. Ran great for the most part after that with a random miss here and there but it was a bit hard to start (had to let the key sit on for a second or two or it wouldn't start on the first try). Was told this might be the fuel filter, replaced that and sure enough it was the original one (sheesh!). Anyway, still didn't totally fix the problem and it started to run rough here and there. Finally threw a code and got P300 (running rich) and a random misfire code. Was given advise that it might be the FPR or spider. Pulled the intake off today and sure enough there was puddled gas around each of the injectors. My original thought was that if it was just puddled under the side of the FPR or not puddling at all then I would replace the FPR. However, since it is around each of the injectors, I am assuming the Spider is leaking and would need to be replaced.
Can someone double check me and make sure I am looking at this properly? Due to the cost of the spider I want to be relatively certain that I am looking at this right. Thanks in advance for your help!
Pressurize the system and look for leaks. The majority of the problems with fuel leaks are at the FPR and at the 'nut kit' (the internal fuel lines).
I decided to bite the bullet and bought a replacement from O'Reilley's Auto Parts and installed it. The funny thing was I didnt have the depressurize the system because it was leaking. Installed it, turned the key on for a second, then it fired right up. This seems to have solved all of my problems and runs great now.
I have some pics of the hacked up spider I'll post in a few minutes.....thanks for the advise swartlkk!!!
just curious, did you ever replace the lower intake gaskets?
Can anyone tell me how to change the spider, a web site with pics would help a ton. Please and thank you.
There are several youtube videos, not all of them good, on the subject. Plus articles here, with pic references IIRC. Which can be found with function bar search or google search {I dont like this site search engine but hey..}
The idea is to not just go by one set of instructions but to fix the big picture in your mind by getting a lot of different input. Then YOU can determine what makes the most sense to you. After that you may feel more confident in how you address repair problems.
One thing to remember is that routing of those lines is very important. Make sure you follow the advice on that.
sirhc76
02-08-2012 09:14 AM
Tinted
11-04-2011 02:29 PM
klausjohn1142
08-05-2008 01:27 PM
