Blinking service engine light
I have a 4.3 2000 blazer today check engine light came on blinking and had a rough idle gas gauge bouncing all over... Any ideas went to pull codes and scanner couldn't find a connection at auto zone any idea on how to fix that as well? Picture just for attention, any help is appreciated.
I think the Check Engine lite blinks a bit as the ECM sets the codes into memory.
Not sure what you mean by could not find a connection at Autozone??...could not find the OBDII connector under the steering wheel, or could not find an Autozone with a GM OBDII cable/connector?
If you could not find the OBDII connector under the dash, then drop the trim panel under the steering column and see if the OBDII connector is there.
Cassera
02-10-2014 06:33 PM
bearsfangb1
09-28-2009 12:19 PM
bir11
06-06-2009 04:05 AM
Mike2Cubed
03-08-2008 08:27 PM
