blower Filter??
blower Filter??
Folks,
It seems my blower on my heat and A/C is not so strong when I don't have it on MAX A/C (recirculate) as soon as it is pulling air from outside there's not very much air blowing.... Is there somekind of filter for the outside air?? It's a 95 Blazer 4.3 L. 4WD
Thanx,
Aqua
Thanx,
Aqua
RE: blower Filter??
No, there isn't, but check the cowl inlets under your wiper arms and see if there is debris in there that might be blocking the air intake.
RE: blower Filter??
^^Yup^^ No filter option available for the S-series. You should definitely pull up the plastic cowl area and check for leaves, pine needles, or any other debris down near the inlet of the fan.
RE: blower Filter??
Those are clear... 'least looking at the plastic grills.. I'm guessing debri sometimes goes through those and gets in there and gets clogged... could it be smaller debris getting plugged in the fins of the A/C core or heater core?
*Combining consecutive posts. Please use the edit function if no one has replied since your last post, thanks. TBB
Is there some sort of grill/grid or is it just an open duct into the fan where smaller debris would go past and possibly plug the fins on the heater core?
Aqua
_____________________________
Aqua
95 Blazer LT 4WD
Aqua
Aqua
95 Blazer LT 4WD
RE: blower Filter??
Aqua
Aqua
maxvamp
10-31-2020 08:19 AM
SWATPARAMEDIC
01-01-2010 03:12 PM
highlife756
11-16-2009 03:57 PM
aspenpup
07-03-2005 06:56 AM
