Bose Speaker specs & replacement
Hi all!
I hope I am putting this in the right place ( I am new, sorry). Anyway, I've got a 99 Bravada with the factory Bose, and a few quick questions that I cant seem to find;
I know that the system itself is powered by an amplifier, and sent through the head unit, but;
Are the Bose speakers themselves also amplified? (Aka small amplifier built in on speaker)
My father & I replaced the rears with Sony x plods, and you can barely hear them, whereas the front by itself is loud as can be! (Maybe I didn't hook them up right?-They old ones weren't working when I bought them).
If they are, are there any rear speaker after-market equivalents? Just so I can get the same sound from the rear as the fronts?
Also, if they are amplified, are there any 4" or 4x6" equivalents for the dash?
There is nothing wrong with the front, just wanted to upgrade,
but from the rear replacement, it seems the original Bose speakers had a built in amplifier, which now explains lack of sound-----I guess they also have a low impedance?
Next,Are the front Bose door speakers just 6" subs or normal bose 6" getting all the base sent to them by the cross-fader? Im pretty sure they are factory, but it sounds like either they are subs or the crossfader just sends all the base to them!
Oh, and one more thing!- While underneath my steering wheel column, I dsicovered what looked like an "Aux Output". It says sony, and looks original, with a yellow zip tie around it. I tried plugging it in but it didnt seem to do anything--- Is this supposed to plug in somewhere? I know my car has the car theft device, a black GPS box under the rear seats, and a black box attached to my window--which all seem to be a "system".
Thanks for any help! I really appreciate it! (Hey, atleast it's easier than the Hu replacement on my Taurus--Stupid radio bezel panel.)
See the link below. I do not believe you will have success running aftermarket speakers with the bose amplifier. Below is a link to a thread in the audio section. The Bose speakers are 1 or 2 ohm and aftermarket speakers are 4 or 8 ohm. The amp is not going to power the speakers very well. Do a search on Bose in the audio section and you should be able to find all the information you need. You might be able to run aftermarket speakers with an adapter attached to the head unit.
https://blazerforum.com/forum/2nd-ge...m-55299/page2/
JohnBarJB
09-28-2020 07:34 PM
unpredictable1
10-26-2014 04:12 AM
stevengrc
02-05-2009 09:19 PM
