A/c Delete Pulley
A/c Delete Pulley
I have been trying to find the AC Delco part number for the a/c delete pulley for my 2004 S10 Blazer 4.3L, 2Dr, 4x4 for a few days.
The parts stores I call say its a dealer item, so I called the dealer, the guy did not even have a listing for the delete pulley. He said its possible that there is no option for that in a 2004 model. Is this right?
I am at wits end with trying to find a solution. I could buy another compressor at $460. The compressor that I have is totally fubar.
Does anyone have a part number from GM or AC Delco for the a/c delete pulley?
Thanks a bunch!!!
Darryl
Thanks a bunch!!!
Darryl
CHEVROLET S10 S-10 BLAZER A/C AIR CONDITIONING COMPRESSOR BYPASS PULLEY AT MONSTER AUTO PARTS
2100015 1999-2004 Chevy Blazer 4.3 A/C Compressor Bypass Pulley 34.95
You will love me forever.
- S10 Blazer With 4.3 Liter (262 CI) 6 Cylinder Engine
- Replaces Seized Or Defective A/C Compressor
- Bracket Bolts In Place Of The Removed A/C Pump
- Bolts In Place With Mounting Locations
- Allows You To Use Your OEM Size Belt
- Includes Correct Size Pulley
- Durable Aluminum Bracket
- High Quality Bearing
- No Modifications Required
- Bypass Pulley Fits 1999, 00, 01, 02, 03, 2004 Chevrolet S-10 Blazer 4.3
Thanks for the reply. Is this an AC Delco part? Something our local Auto parts stores may recognize that part number? The shipping is USA only, I am in Canada.
Thanks
Thanks
Its a dorman part. For something like this i wouldnt worry about it not being oem. As ive had one on for a LONG time and never any issues. If it was a fuel pump,etc that'd be different.
that site says up to 04,everyone else says up to 03. Check your compressor and see if the bolt holes are the same etc. It should work.
The compressor mounts with 4 bolts, no problem, other than having the measurements of the distance between the holes themselves it looks like it will fit. But I can't order from that site as it only ships to USA. Will try to locate a Canadian retailer with this part I guess.
Thanks
Thanks
Gomli
01-20-2012 10:26 AM
chevblazer02
10-31-2006 09:36 AM
