A/C low pressure switch
Last summer I had to top off my A/C system with R-134a. I must have a slow leak somewhere. Over the winter it has seemed to almost all leak out. I topped it off again, but my compressor clutch still wont engage. If I put 12v directly to it, it will engage. On the dryer there is a socket where it looks like there should be a harness plugged in. This is the low pressure switch, correct? There are no wires/harness plugged into it. I looked all around for the harness dangling somewhere. I can't find it anywhere. I don't know how it ever got unplugged. Can anyone tell me where I might look for it, or maybe have a picture? I searched the internet and can't find a good one. It has to be somewhere close. I checked all fuses and everything, and like I said everything work great and is ice cold when I put 12v to it and engage it "manually". It's a 99 ZR2 4.3L if any of that matters
Thanks
Thanks
I figured that was the low switch because it's on the same component (dryer) as the low pressure port to add R134a. Anyway, I found the harness that plugs in this morning. I was looking for it coming from the middle of the engine bay where a lot of the other wires come from. It come from the other side closer to the fender. Everything is good now 100%. Besides the leak I guess.
Thanks
Thanks
my 04 blazer has 2 plugs over there for some reason... not sure if the previous owner spliced one in and never removed the old one? AC didn't work either way when I got it, I'm working on that now lol
The switch on the accumulator is the clutch cycling switch. The switch engages the clutch when low side pressure is above ~42psi, and disengages the clutch when low side pressure drops to ~22psi. The switch on the rear of the compressor is the high pressure cut out switch. If high side pressure is excessive, (~375psi or more) the ground circuit for the clutch is opened and the clutch disengages. If either switch is unplugged, the clutch will not engage.
rknight
17
07-09-2010 11:30 PM
ronaldo
04-01-2010 06:24 AM
96BlazinLS
14
07-14-2009 07:43 AM
