changing front axle
changing front axle
ok ive done alot of serching with no definite answer.i need to change a front pass. axle on my wifes 99.im gonna do both ball joints as the top is factory and the bottoms been in for at least 5 years.i know to pop both ball joints, loosen the axle nut and drive out axle from hub.but how does the axle come out of diff?most of my searches come up with prying it out because of a snap ring and another said there are 4 bolts.i would like to know what to expect.thanks for any help.
yes you can pry at the cv shaft to get it out. or use a board and tap it with a hammer to get it free. once the hub and spindle are out the way it is pretty easy to do. you might as well do the seal there at the axle tube messing with it will probably cause a leak.
this may help you out.
https://blazerforum.com/forum/articl...le-seal-62365/
If you rent these 2 tools, it's amazing how fast & easy the axle pops out! One smack and it's out, piece of cake.
OEM/5 lbs. Slide Hammer (27033) | Slide Hammer | AutoZone.com
OEM/FWD Axle Puller Adapter (27058) | FWD Axle Puller Adapter | AutoZone.com
Excellent idea to replace the axle seal while you've got the axle out.
chowell
03-06-2021 09:47 PM
blajeans
01-09-2013 12:58 PM
iamchevyman5
32
12-20-2012 11:20 AM
danielcoins
07-03-2011 10:53 AM
lemon blazer
06-28-2007 07:46 PM
