Changing the headlight bulbs on a 97 Blazer
Can anyone tell me how to change the headlight bulbs on a 97 Blazer? Thanks!
RE: Changing the headlight bulbs on a 97 Blazer
do you have your owners manual?
Yes-
Will it tell me how? Looks like I need to pull out the grill. |
For composite headlamps:
Remove of Disconnect: 1. Plastic Caps that cover the headlamp retaining pins. 2. Headlamp retaining pins. 3. Headlamp from the vehicle. 4. Bulbs from the headlamp by pushing in and rotating them 1/4 turn counterclockwise. Install or connect: 1. Bulbs to the headlamp by pushing in and rotating them 1/4 turn clockwise. 2. Headlamp to the vehicle. 3. Headlamp retaining pins tightened to 62 lb.in. (7 N-m) 4. Plastic caps that cover the headlamp retaining pins. Remove or Disconnect: 1. Screws that retain the headlamp retaining ring. 2. Headlamp retaining rings. 3. Headlamp from the vehicle. 4. Headlamp electrical connector. Install or Connect: 1. Headlamp electrical connector. 2. Headlamp to the vehicle. 3. Headlamp retaining rings. 4. Screws that retain the headlamp retaining rings. *EDIT* - Also listed in the owner's manual page 6-33 thru 6-35. |
