changing spark plugs
Old 04-18-2008, 06:40 PM
quick's Avatar
quick is an unknown quantity at this point
Default changing spark plugs
Does anyone have a tip on changing the plugs that are up by the firewall? You know, the ones that are hard to get to? This is for a '95 s-10 blazer with a vortec engine (v-6)
Old 04-18-2008, 06:43 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: changing spark plugs
go thru the wheel wells.... Jack it up take off the wheels...
Old 04-18-2008, 06:51 PM
quick's Avatar
Thanks alot 2002xtreme,
I'll try this as soon as the rain stops. By the way, would you recommend platinum plugs?
Old 04-18-2008, 07:00 PM
Factory plugs were AC Delco double platinums. Probably the best plug for this engine.
And yeah, go through the wheel wells.
Old 04-19-2008, 10:14 AM
maki3242@gmail.com's Avatar
maki3242@gmail.com is an unknown quantity at this point
On my 98 2dr 4x4 it was easiest on the 5th plug ,I think, to disesemble the steering column and have the wheel removed as well
Old 04-19-2008, 11:13 AM
That would be the 3rd plug. The 3rd plug should be tried in quite a few different ways first before going through the removal of the steering column.
Old 04-19-2008, 02:41 PM
black powder is an unknown quantity at this point
for the # 3 plug use the SNAP-ON tool #s9723
url=http://www.servimg.com/image_preview.php?i=183&u=10060487][/url]
Old 04-20-2008, 03:27 PM
theonetrueapex is an unknown quantity at this point
I have never seen that tool before, but yes there are many threads about the dreaded #3 plug.
Old 04-21-2008, 07:26 PM
Brocktward is an unknown quantity at this point
I bent a cheap box end wrench to about 30 degrees and was able to change the plug with it.
toms2000blazer
12-20-2015 07:23 PM
Yankee Team1020
23
08-03-2011 08:05 AM
gsmollin
05-04-2010 10:18 PM
instygator
01-20-2007 08:38 PM
nofear17bmx
12-21-2006 12:07 AM
Quick Reply: changing spark plugs
