Check
Check
I had the Blazer scanned and the code said the 4lo switch is the problem. Is there any way to check to see if it is the problem. I got another one from the wreckers and it still did the same thing. I have a 4 button (NP8) Or any other solutions? Thanks
He never gave me the code.
Is it possible that the switch from the wreckers is no good? Or is it possible there is a wire crossed when he replaced the connecter to the TCCM. He says the wiring is right.
Last edited by rriddle3; 02-20-2010 at 02:12 PM. Reason: COMBINING CONSECUTIVE POSTS
sorry Danny, i never even thought to give you the codes when i scaned it today.
i retrieved;
-P1845: 2-3 shift solenoid circuit low input,
-P1875: 4WD LOW switch circuit electrical.
i also retrieved a P0138 from your truck as well.
i retrieved;
Ok thanks Now what should I do. I wish I had another switch to try and see if it fixes it or is there another problem. Just hope the mechanic never crossed a wire.
you think I should get a switch or just have somebody look it over?
Last edited by rriddle3; 02-21-2010 at 07:30 AM. Reason: COMBINING CONSECUTIVE POSTS
it should also be noted that he (irishdude) also had the TCCM rebuilt. the shop that did the rebuild also benched tested it before returning it.
just giving you guys more of the info that he relayed to me on Saturday while i was @ his house.
you should also look for Kyle's thread on how to diagnose the 4 button switch.
