compass and thermometer wiring
hi everybody.
Does anybody have the wiring of basic compass and thermometer module? I mean wiring of how-to connect this module in installation. This module was stolen and need to install the same one in the right way. Blazer 1996.
Thank you.
Thank you.
RE: compass and thermometer wiring
what exactally was stolen? The unit out inside of the grille? Near your bow tie emblem? JP[:@] damn thieves
the module with display from inside, which shows temp and directions. It was stolen about a year ago when my friend had this vehicle.
ever try a pick and pull? There you could possibly salvage some wiring also and splice it back together along with the assembly. JP[&:]
Yes,
actually I've already found another plastic board which located on interior roof with temperature and compass display, front and rear interior lights and all these bunch of pockects.
I'm gonna install this soon, that why I ask about wiring (electrical drawing).
is all or how much wiring is gone-if you got another one you either have( or hopefully could have) the wiring that attaches to it-if same year(or ?) colors should match up- and go from there. JP
try searching for overhead display on this site I had a problem with it and someone posted a diagram for me. Ill look for it too.
Where IS the thermometer on my Jimmy? Behind the GMC on the grill? Mine's been screwed up forever. It'll read fine for awhile......it's 70 degrees....then look up, and it's 20! It's either right on, or off my like 50 degrees. Would that be the thermometer itself, that's bad?
KRUSHER
01-16-2010 10:38 PM
nslide10
12-20-2005 04:25 PM
