crankshaft sensor
Old 03-06-2013, 06:14 PM
beater blazer's Avatar
beater blazer is on a distinguished road
Question crankshaft sensor
hi new guy here i am having trouble getting the right crankshaft positioning sensor parts place sent two both wrong too big wont fit in the hole old sensor pulled out broken that is the small magnet had to be fished out with a small pick never changed one before am idoing something wrong besides not being able to type good please give me in put
Old 03-06-2013, 06:25 PM
Year, make, model & engine would help
Old 03-07-2013, 06:30 PM
ok sorry its a 1999 s10 with a v 6
Old 03-07-2013, 06:33 PM
Default crankshaft sensor
the truck is a 1999 s10 with a big v six motor
Old 03-07-2013, 06:39 PM
Unbolts and pulls out, should look like this: Buy Delphi Crankshaft Position Sensor SS10125 at Advance Auto Parts
After replacement, the crankshaft position sensor relearn MUST be performed with a capable scan tool. The engine should start and run, but it will not run properly until the relearn is performed.
Old 03-08-2013, 07:15 PM
ok got the old sensor out the base was stuck in the case how do you do a relearn? thanks steve
Old 03-08-2013, 07:24 PM
The crankshaft position sensor relearn can only be performed with a (high end) capable scan tool. Any GM dealer can do it, and some independent shops can do it. You'll need to call around and see who has a scan tool capable of initiating the relearn, and is familiar with how to perform it. Labor charge should be less than 1 hour.
Old 03-28-2013, 07:02 PM
Default crankshaft senser
thanks for the help did the relearn and still didnt fix the problom the mechanic i know thinks it could be a timing chain anyone else ever have the same problem thanks steve
Old 03-29-2013, 12:38 PM
spittybays
Guest
Posts: n/a
uh...what is the problem?
johnbrown06
11-26-2009 05:16 PM
agent305
06-10-2008 02:56 PM
PhillyZ
03-18-2008 12:00 AM
DecaYedZombiE
02-13-2008 10:34 PM
murfthesurf4
11-26-2007 11:54 AM
Quick Reply: crankshaft sensor
