Current All Aluminum Radiator Options?
Old 02-11-2019, 04:32 PM
christine_208 will become famous soon enough
Default Current All Aluminum Radiator Options?
So I am shopping for a replacement radiator and am curious as to what people have found and their experience with all aluminum radiator for our 4.3L Blazers.
I need one with the fittings for both the transmission cooling lines and the engine oil cooling lines. It is the later option that seems to be lacking in most of the aluminum radiators I have found.
Here is a list of the ones I've found that have all of the fittings I need. I'd appreciate any and all comments by those who know of them or have installed them. Of course if there are ones I have not listed please add your link and your thoughts on it.
Thanks!
[Edit: I do tow with my truck so any added advantage with regard to cooling ability is desired.]
Radiator Express; "1 row radiator delivers upgraded 2 core cooling at an affordable price. (1-1/4 thick core design)" $185
Radiator 1999 Chevrolet Blazer - 4.3 Liter V6 262Cid Radiator All Aluminum 1 Row, With 2 Coolers | Radiator Express
Prime Cooling Radiators: "Primecooling 3 Row All Aluminum Radiator for Chevy S10, Express 2500 /GMC Jimmy,Safari/More 4.3L Models 1995-2005" $184
https://www.amazon.com/Primecooling-Aluminum-Radiator-Express-1995-2005/dp/B01K6TEXPM/ref=sr_1_3?keywords=aluminum+radiator&qid=154%E2%80%A6 https://www.amazon.com/Primecooling-Aluminum-Radiator-Express-1995-2005/dp/B01K6TEXPM/ref=sr_1_3?keywords=aluminum+radiator&qid=154%E2%80%A6
Auto Radiator: "KKS1826 New 3 Rows All Aluminum Radiator Fit 1996-2005 Chevy S-10 Truck Pickup V6" $199
https://www.amazon.com/KKS1826-Aluminum-Radiator-1996-2005-Pickup/dp/B07FD8HTPM/ref=sr_1_8?keywords=aluminum+radiator&qid=1549735%E2%80%A6 https://www.amazon.com/KKS1826-Aluminum-Radiator-1996-2005-Pickup/dp/B07FD8HTPM/ref=sr_1_8?keywords=aluminum+radiator&qid=1549735%E2%80%A6
Pro-Tuning Lab:
Aluminum Tri Core 3-Row Radiator:
  • Stronger & Higher Capacity for Coolant than Stock Units
  • Made of High Quality Full T-6061 Aluminum Construction
  • Direct Bolt-On OEM Fitment or Replacement
  • High Performance Euro Spec. 3-Row Racing Design
  • Core Size: 27" x 16.25" x 2"
  • Inlet/ Outlet: 1.50"/ 1.75
  • Improves cooling by 35 - 45% temp.
https://www.protuninglab.com/dna-ra-fs-chevy-96-3.html
Liland Global at CarId.com: "Core Height: 26-1/4; Core Width: 15; Thickness: 1.26"
https://www.carid.com/1999-chevy-bla...302380704.html
manufacturer website: http://www.showmetheparts.com/liland/, pn 1826AA
Engineered Cooling Products: "Chevy S10 1995 - 2004 Aluminum HD Radiator - 2-rows of 1.0" Cooling Tubes" out of stock
https://www.speedcooling.com/Chevy-S...ing-Tubes.html
UPDATE: Feb. 26, 2019
In case anyone finds this thread, as of Feb 2019, I was not able to find any domestic suppliers of all aluminum radiators for our Blazers. I excluded the ones on eBay and Amazon as they are of questionable design and quality. The one domestic manufacturer that I found had discontinued their radiator for Blazers (speedcooling.com). I thought I had found an OEM style radiator from Misimoto that had a thicker core (1.375" vs. 1.0") but when it arrived it too had a core of only 1.0". There is a radiator that can be purchased from Advance Autoparts that lists its core thickness as 1.375" also but I have not been able to confirm if it really has a thicker core or if it is mislabeled like the Mishimoto one. I suspect the later but I hope someone can report if it really is the former.
UPDATE: March 7 2019:
Apparently Engineered Cooling Products is carrying the radiator again. (See post for 3/7/2019). This is the only apparently domestically manufactured radiator for our 2nd Gen Blazers. I have an email from them that they do manufacture their radiators in Chicago.
Last edited by christine_208; 03-08-2019 at 04:07 PM. Reason: updated search results
Old 02-11-2019, 04:57 PM
Following
Old 02-12-2019, 05:28 PM
Old 02-12-2019, 05:34 PM
cleburne red's Avatar
Damn, my radiator might start leaking at some point soon. Shame you can't fix those plastic side tanks. Looks like I'll have to pick up one of these!
Old 02-12-2019, 06:51 PM
Added a couple more radiators to the list in the starting post but some of them are out of stock.
If anyone has any experience with these, please post about it.
Thanks.
Old 02-13-2019, 08:52 AM
go chevy's Avatar
I would suggest you get a screen/shield put in the grill if you don't have 1 already... Stupid little rocks from the road are a menace lol
Old 02-13-2019, 11:59 AM
I'm now getting quite discouraged with trying to find an all aluminum radiator with extra cooling capacity. I've even tried looking for the plastic/aluminum ones with extra cooling capacity but cannot find any. Ugh.
If anyone has any suggestions for any radiator with extra cooling capacity, all aluminum or not, please let me know.
Old 02-13-2019, 01:25 PM
The pro tuning lab one says it has extra capacity, and comes with two fans mounted. Currently out of stock, though
Old 02-14-2019, 10:20 AM
jimspahr@msn.com's Avatar
When you install a two electric fan set up on a Blazer with the stock mechanical single cooling fan, it would seem you would have to have some elec. connection to interface with the engine cooling system to turn the elec. fans on and off. Is that correct ? How is it done ?
Old 02-14-2019, 10:39 AM
Not sure. Maybe it comes with a temp sensor of its own it uses to turn them off and on?
Quick Reply: Current All Aluminum Radiator Options?
