Dang e brake please help
Old 03-02-2012, 01:00 AM
Black99blazer's Avatar
Black99blazer is on a distinguished road
Default Dang e brake please help
My e brake is stuck to the floor and the cable won't release it...how do I release it? It's a new truck I don't know my way around it yet
Old 03-02-2012, 12:00 PM
K1500brute's Avatar
K1500brute is on a distinguished road
Going to need more info is there tension on the brake its self or the release handle. when parked put in neutral and try to rock it. if it moves the brake cable most likely snapped. below is a pic of it and a link on how to adjust it
ill try to help had a simular problem on my K1500 and i just basically cut the cable. its just a parking brake and its not worth it to fix. Someone will eventually give you the right answer on how to fix it right but in the mean time you are going to look at the mechanism its self. It could be that the lever to pull the parking brake is loose and not working and dont cut the cable yet cause it also could be that the brake its self locked up.
How to Adjust the Parking Brake on a '98 Blazer | eHow.com
Old 03-02-2012, 07:15 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
K1500 put up a good pic of the mechanism
my blazer would not release till i found the cable where the u shape hook that holds it had popped out it was just sticking up in the air so I put it in the u shaped hook and bent the hook around the cable so it could not come out took about 30 seconds and it has worked fine
Old 03-02-2012, 08:15 PM
LMAO Stay away from eHow, andhow, totally inaccurate! They must be on drugs!
Loosen the adjuster on the cable, (inside frame rail, driver side, almost directly below the driver seat). Remove the rear rotors and turn the adjusters on each wheel until the park shoes drag very slightly on the park brake drum. Adjust the cable so the park pedal goes down 2 clicks and holds the vehicle. eHow ha ha ha ha
Old 03-03-2012, 02:51 PM
newguy's Avatar
Rotate front wheel?
Old 03-03-2012, 03:55 PM
Yup, front wheel????? what's this guy smokin' I want some!
Old 03-03-2012, 04:16 PM
Blazer_LT's Avatar
Blazer_LT is on a distinguished road
for me i use it to keep the gf from driving mine. the release cable mounts into a lil hook. if you feel up into the dash above the pedal you can feel the hook that you need to pull on to release the pedal
Old 03-05-2012, 12:32 PM
K1500brute's Avatar
XD yeah i know i was trying to give him a starting point and see if he would even reply but of course he never did
Chevy33
01-07-2012 06:19 PM
zr2dan
11-17-2011 08:16 PM
RolingKCBlazer
02-18-2009 02:48 AM
86S10
12-19-2007 03:01 PM
Debaser
02-07-2007 12:17 AM
Quick Reply: Dang e brake please help
