deer hit 01 blazer/headlight problem
My son's 01 blazer was hit by a deer. It took out the drivers side headlight,grill and turnsignal.I replaced the headlight and It works but both lights look dim and will not work on high beam. When I disconect the new light the other headlite works fine. I don't know what to do .the wireing was not damaged that I can tell. I think I need a wireing diagram for this vehicles lighting cicuit. Any one have any suggestions.
RE: deer hit 01 blazer/headlight problem
Check the grounds!
Also check the fuse relays for your high beams
I checked the fuses under the hood and that was the problem.Thank you for the info
95chevrolets10blazer
11-14-2011 08:42 AM
altoncustomtech
07-29-2011 06:09 AM
