died on road
Old 11-20-2007, 08:50 PM
dhspark's Avatar
dhspark is an unknown quantity at this point
Default died on road
2001 s10 blazer battery light came on and gauges went crazy and it stopped running,put in new battery and it won't start. thought maybe alternator is junk, but I figured the new battery would have at least started it. also fuel gauge reads empty but I know there fuel in the tank because I added some. anybody have any ideas.
Old 11-21-2007, 02:07 PM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
Default RE: died on road
I'd pull the alternator and have it bench tested at AutoZone (free service). Also, now would be a good time to check and/or replace the battery cables. I once had a Ford truck with battery cables that looked fine on the outside, but were corroded on the inside, thus causing a no start problem. Installed new cables and that truck came right back to life. Good Luck.
Old 11-21-2007, 10:34 PM
WolfPack's Avatar
I had an '87 pontiac that did the same thing then died while after trying to accelerate from a stop. Turned out the ground wire from the battery blew out causing all sorts of shorts making the dash go crazy. Car ended up dying cause of a blown fuel pump fuse, no physical damage (besides the wire) luckily.
Moral of the story, check your battery cables like junkmonkey said, and check from blown fuses
Good luck!
Zasder
12-09-2007 09:25 AM
quinnman105
12-03-2007 03:06 PM
hayndaddy22
11-22-2007 09:53 AM
57chevy
02-13-2006 04:40 PM
Charidy
08-22-2005 02:18 PM
Quick Reply: died on road
