distributor travel???
Old 11-23-2012, 03:43 PM
metroid_killer@hotmail.com's Avatar
metroid_killer@hotmail.com is on a distinguished road
Default distributor travel???
Within the last two months I've gone thru two rotors in the distributor cap. both times the tab in the center of the cap have broken off. With my bare hand i can rotate the rotor slightly counter clock wise and has up and down travel of approx 1/8 to 3/16 of an inch. Is it time for a new distributor or a buddy said replace the gasket cause over time the gasket shrinks and allows travel up and down to happen and this is whats causing the rotor to fail.
Any ideas out there?
Old 11-24-2012, 02:25 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
id start off with a gasket but id also think about getting the bearings checked on the disy
Old 11-24-2012, 10:45 PM
abig84's Avatar
yeah it should only go up and down like a hair. if its actually spinning up and tearing into the cap with the rotor the distributor is bad. ive seen it a few times
Old 11-25-2012, 07:52 AM
The inner shaft of the distributor had come free allowing the movement. Once I pulled the old one out I could move the gear up and down almost a 1/4 of an inch. I had never changes a distributor b4 but it went smooth as could be and the truck is running great 185,000 miles here we come
ethan.zick
04-27-2010 08:49 PM
Spectreblazer
02-25-2010 12:09 PM
king22
Suspension Tech
09-25-2009 04:20 PM
Patrick_Boyle
04-06-2009 08:43 PM
painter
06-24-2007 04:41 PM
Quick Reply: distributor travel???
