Drive Shaft problems please help!
Hey everyone so today i went to replace my u joints due to the harsh vibration i was getting while driving, i marked everything like usual and got the driveshaft out with little effort then used the normal method to pound out the old u joint and was shocked at what i saw.
Pretty messed up IMO. anyway i was trying to install the new one which i am sure i have the correct part and i could not get the second clip to seat properly. and when i finally did it was wayyyy to tight to be correct, so im assuming somewhere along the way my driveshaft yoke got bent. does this seem like a safe assumption to everyone? If so is the only way to fix it by getting a new driveshaft?
Thanks in Advance!
-Derek
Thanks in Advance!
-Derek
If you don't clean up the inside of the yoke where the clips seat with a flat file, they can be difficult to get the joint to free up. I usually use my vice to support the cross pins on the u-joint and then hit the yoke behind the cup. Flip & repeat a little at a time to seat the cups deeper into the yoke and free up the joint.
What part didn't you get?
When the joint is out, you can clean off the inner surfaces of the yoke with a flat file to allow for proper seating of the clips on the new cups. Look where the clips are now and what surface they are resting on.
Now, for your joint that is installed, you may ruin it if you were to remove it. So to loosen it up, orient the tight side of the joint vertical and then adjust the vice to support the other side. Tap on the top of the yoke to seat the cup deeper into the yoke. Flip, repeat, flip, repeat...until the joint has freed up.
Blade_24k
02-26-2014 03:03 PM
camp12
11-09-2011 10:50 AM
deedub711
04-19-2011 09:11 PM
lizzj70
06-23-2010 06:57 PM
