Engine died when put in gear
Started up and when I put in gear it just instantly died. Now it will not even attempt to crank in park or neutral. Fuses, relay, battery are good. All lights work, radio, all accessories. Need advice. Ignition control module? Switch? Thanks
Then your ignition switch is good or at least the start position portion is.
Lets go to the other end. When you turn your ignition switch to the start position do you have 12V on the purple wire connected to the starter?
George
George
SCblazer71
09-24-2019 11:32 AM
slagburger
02-13-2012 04:55 PM
mjhoffman48
03-01-2011 12:10 PM
