Engine noise and trying to figure out
Old 10-24-2010, 01:17 AM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Default Engine noise and trying to figure out. Please Help!
When i first start the truck from a cold start my truck makes a sqeaking/sqealing noise when it starts up and gets faster when the rpms increase. After about 10 mins it will go away. Also when the rpms increase to around 3k-5k it makes that a ticking/sqeak noise i do believe is the same. I had replaced my idler pully already which was really bad, along with the tensioner i though was possibly hitting on the stop making a the noise and possibly bad bearing in pully, and my alternator. It sounds like its coming from the middle of the motor from around the crank by the water pully/clutch fan. Anyone know how i can try to figure this out other than replacing everything? Thank you
Old 10-24-2010, 10:26 AM
1998MSO's Avatar
1998MSO is on a distinguished road
Did you also replace the serpentine belt when you changed the idler pulleys?
That would be my first guess.
Old 10-25-2010, 12:01 AM
PaulO2288's Avatar
Yeah its got a new belt
Old 10-25-2010, 11:51 AM
1998MSO's Avatar
Hmmmm...the only thing I can suggest is to take the belt off and spin everything by hand, such as the pulleys, alternator etc... If any of 'em don't spin freely or make some noise, you've probably found the source.
Old 11-01-2010, 06:10 PM
o2beme68's Avatar
o2beme68 is on a distinguished road
Default engine noise and trying to figure out
I thlnk it's the fan clutch myself. I have a noise that's sounds like metal rubbing metal with a ticking sound. I recently put a new motor and trans in
everything is original except the water pump. my ac quit working also . im going to replace the fan cluth this week. also the fan is constantly turning. I thought its only supposed to turn when the temperature reaches 195 f. I'm really stumped one this one. I took the belt off and started the engine and no noise so i know it's a bolt on part.
darknight
09-02-2011 08:07 PM
chevyblazer9588
08-05-2011 08:44 PM
Arby24
06-22-2011 07:52 PM
chevfan2000
06-08-2010 05:59 PM
Leo_P3547
03-28-2010 11:28 PM
Quick Reply: Engine noise and trying to figure out
