Failed emissions need to fix some stuff
ok so i brought my 1998 Blazer LS to get it thru the emissions inspections and i failed. The results show im running codes P0452 and P1870. They said i failed because the 452 code whichreads Evaporative Emission System Pressure Sensor/switch Low. I dont have a whole lot of cash to spend on a mechanic (since i still need to register the vehicle by friday before i get charged more.. which sucks..)So i was wondering if this is something i can fix myself. It just seems like something needs to be replaced and imno mechanic but i know my way around a car so im pretty confident in myability to doit and save the money.
RE: Failed emissions need to fix some stuff
Here ya go on the codes:
P0452 Explained
P1870 Explained
Have a read through them and ask any questions you may have about them.
P0452 Explained
P1870 Explained
Ok starting with the 452 it looks as if it could be pressure related. I did recently replace the gas cap because it was loose, could this be a condition to set off the code?As for the 1870 code, I didnt really understand it so i think im stuck to bringing it to a shop
It doesn't solve the problem, but what I did was stop by the closest AZ to the emissions testing station and ask them to clear the codes for me or that I would just have to rent the obdII tester to do it myself, theydid oblige and passed my emissions test.
Interesting. They must not plug in... When you clear the codes, it also resets the emissions monitors which requires a completed drive cycle (or many drive cycles) to go from "not ready" to "ready".
well... they did just plug into the computer they didnt hook me up to any sniffer.... I dont know I will see what i can do. Like i said i only have til friday til i have to register my car.
89Jimmy4Free
12-06-2010 10:32 PM
dannyek7
06-04-2010 07:53 PM
dyeraudio
03-07-2009 07:15 PM
