Front 4WD Differential gear oil substitute?
Old 02-05-2014, 10:49 AM
cleaveley's Avatar
cleaveley is on a distinguished road
Default Front 4WD Differential gear oil substitute?
Hi guys I am just wondering if there is anyway I can substitute gear oil for something like motor oil or ATF fluid??
I have a 2002 Chevy Blazer 2DR 4WD thanks !
Old 02-05-2014, 11:23 AM
You could pour water in there if you were so inclined...but don't expect it to last too long that way...
To less sarcastically answer... No, you should not use motor oil or ATF where gear oil is required. Neither of the two have the shear properties required to protect the components inside the differential. It isn't like 80w90 GL-5 gear oil is all that expensive or readily available at almost any store that carries oils in general.
Old 02-05-2014, 02:14 PM
Diaita's Avatar
Diaita will become famous soon enough
Agreed, the $15(exaggerated) you'd save by putting anything else in the differential would cost you hundreds later.
laura8088
Tires and Wheels
06-20-2014 08:32 AM
Drew4711
10-06-2012 12:47 PM
remm jake
04-09-2011 10:22 AM
ExplicitYourSelf
06-16-2009 09:26 PM
98BlazerLT4x4
03-04-2008 06:00 PM
Quick Reply: Front 4WD Differential gear oil substitute?
