front brake pad replacement...
Old 10-06-2007, 05:23 PM
johnnyblaze's Avatar
johnnyblaze is an unknown quantity at this point
Default front brake pad replacement...
my pads are just about done on my 96 blazer...how do I take the caliper off to replace them..
thanks alot...I do not have expierenec with chevy brakes yet
thankss
John
Old 10-06-2007, 05:33 PM
Default RE: front brake pad replacement...
Remove the caliper bolts and lift up on the caliper. Clean and lubricate the slider pins with high temp caliper grease. Clean or replace the shims that the pads slide on. Install the new pads after removing the worn out ones. Push the caliper piston back in with a c-clamp. Reinstall in reverse of disassembly.
Old 10-06-2007, 05:52 PM
im not seeing the valiper bolts I see 2 slider things...where abouts are they located ...maybe i should take a look tomm getting to dark out
Old 10-06-2007, 06:04 PM
Bolts are on the back side of the caliper. Being a '96, you probably have single piston calipers. I believe you will have internal hex head bolts to remove that will have sleeves assembled onto them.
Maybe this will help - Single Piston:
Two Piston:
Old 10-06-2007, 07:36 PM
blazin97's Avatar
blazin97 is on a distinguished road
96 is the simgle piston with a hex head you have to get from behind the caliper
Old 10-06-2007, 11:50 PM
filtalr's Avatar
filtalr is an unknown quantity at this point
[align=left]Like Kyle said it takes a BMF c-clamp to compress the caliper piston and a tip is to use one of the old pads placed in the caliper for a flat and even push on the piston. Also remember to support the caliper at all times - if you're not holding it in hand -- hang it by a heavy wire (I have a section of stout wire coat hanger cut and saved just for that purpose) and never let it hang by the line.
[/align][align=left] [/align]
KRUSHER
04-18-2010 09:50 PM
XTREME POS
05-29-2008 09:05 PM
Blindthieves
10-28-2007 06:35 PM
flyinbrad
09-28-2007 02:21 PM
Acer2428
07-13-2006 11:52 PM
Quick Reply: front brake pad replacement...
