Hard to start on cold weather....
Old 01-17-2019, 12:39 PM
David12's Avatar
David12 is on a distinguished road
Exclamation Hard to start on cold weather....
Good day everyone, I having an issue with my blazer 96 4.3, it's Taking a long time to start in the morning and when finally starts up it wants to die and surges upon acceleration. So far, I've change spark plugs cables and spark plugs, distribuitor cap and rotor, my mechanic checked the fuel pressure regulator and also the fuel inyectors for any leaks but he said that it's good meaning no leaks, he also checked for any codes and he just got oxygen sensors, any help will be really appreaciated, thanks.
Old 01-18-2019, 08:07 AM
go chevy's Avatar
Once it warms up the problem goes away then? Like running errands, turning the truck off and then restarting it with no problem?
Old 01-18-2019, 12:52 PM
Mike.308's Avatar
Ask him to measure the fuel pressure too (howto in the sticky threads) O2 sensors are "suppressed" while engine is cold.
Old 01-23-2019, 08:31 AM
David12's Avatar
Go Chevy, sometimes once gets warm the problem goes away, once the truck finally starts if I turn it off and on it would start with no problem but if I want to start it after a few hours I will have the same issue.
Old 01-23-2019, 08:33 AM
David12's Avatar
Mike, he checked the fuel pressure yesterday and said that it has really good pressure 55_60 psi.
Old 01-23-2019, 09:26 AM
go chevy's Avatar
Maybe it might need a new fuel filter??? Just a guess on my end...
Old 01-25-2019, 07:22 AM
David12's Avatar
Fuel filter has been changed with no good results.
Old 01-25-2019, 08:17 AM
go chevy's Avatar
Maybe try pouring a bottle or 2 of SeaFoam injector cleaner in your gas tank...
Old 01-25-2019, 05:38 PM
Mike.308's Avatar
If You run it cold, does it run rough? If You have the device for listing codes You may use it to post the fuel trims (LT/ST both banks) of a cold engine right when it starts. Then we could think of something out of this data.
On second thought please update readings with MAF, MAP, coolant temp.
98SmokeBlazer
16
02-19-2013 02:20 PM
netslinger727
12-30-2010 08:32 PM
uncledenny
01-28-2010 05:36 AM
kewasson
12-20-2009 12:37 PM
vmx120
12-02-2005 12:19 PM
Quick Reply: Hard to start on cold weather....
