Hard To Start When Cold Outside
Old 02-18-2013, 08:53 PM
No fuel flow was allowed to get to the plenum, correct?
Old 02-18-2013, 08:55 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Did you ever do the tuneup?
Old 02-18-2013, 08:59 PM
98SmokeBlazer's Avatar
98SmokeBlazer is an unknown quantity at this point
I don't think so. I completely removed the quick connect fitting from the filter (outgoing side) and attached the pressure gauge to that side of the filter with the quick connect line hanging down.
Old 02-18-2013, 09:03 PM
Only replaced the fuel filter. checked a few plugs and they looked good. also check spark with a tester and had good spark. I am still planning on doing plugs and wires but im kind of stuck on the fuel delivery issue now.
Old 02-18-2013, 09:12 PM
Perfect!
This quote is from post #8:
"Checking fuel pressure at the service port indicates regulated pressure or maximum pump output pressure, whichever is LOWER. This is why the pressure needs to be checked at the filter... to make sure the pump can supply enough pressure to satisfy the regulator."
The pressure reading you got of 55psi is all the pump can supply to the injectors and regulator, and it's about half of what it needs to be. The regulator was not being satisfied so it wasn't / isn't bypassing, (regulating) any fuel. It's also why the engine runs poorly. This is a perfect example of why it's so important to check "dead head" pressure.
Now you need to drop the tank down far enough to unplug the module connector so you can check voltage on the grey wire during pump prime. Needs to show battery voltage. Then check resistance on both black wires to ground. Must be less than 5 ohms. If voltage & resistance are OK, drop the tank and remove the fuel pump module. On the top of the pump motor there is a 3/8" flex hose that runs up to the module housing. There is a clamp on each end, make sure they're tight nd that there are no cracks in the line. Post your results.
Old 02-19-2013, 02:18 PM
Did all checks with ok results, so I went ahead and put in a new fuel pump. After reassembly she started right up. Thanks for all the advice and useful info in diagnosing problem. Very much appreciated.
Old 02-19-2013, 02:20 PM
Glad you got her going! Might not be a bad idea to check pressures again and write them down for future reference.
bolivier
12-06-2013 04:08 PM
RobMacLin
01-21-2013 09:15 PM
Sand crab
01-03-2013 09:20 PM
TinCanJohn
08-13-2010 12:07 AM
proper
01-13-2010 06:49 PM
Quick Reply: Hard To Start When Cold Outside
