which headlight bulbs for 96
before i go to the store which bulbs are for the daytime lights, high beams, low beams... i tried looking online but it said about 10 different bulbs... which are for what ###owned a blazer for 2 days### lol
RE: which headlight bulbs for 96
I'll answer your question, but you'd definitely get more help if you posted this in the General Tech Help section.
Assuming that you have a composite system, your high beam will be a 9005 and your low beam will be a 9006. Need more info? http://www.autozone.com <---Clicky |
what about daytime bulb? and thanks
The Daytime running lights use the high beams at either a lower supply voltage or a lower supply amperage (can't remember off the top of my head right now). But anyway, there isn't an additional DRL bulb.
*EDIT* - will move to the General Tech Help section. |
On my 96 it uses 1 buld for high, low, daytime running lamps
Yes, there are some blazers with a dual filament bulb that runs both high, low, and DRLs. The housings are generally larger.
