Heat Doesnt Seem To Work
Old 09-25-2011, 09:50 PM
EricR's Avatar
EricR is on a distinguished road
Default Heat Doesnt Seem To Work
Well this is a strange problem. I didnt even know it was possible to be honest. I turn the heat on in my Blazer and it doesnt seem to get hot just sort of a slightly warm but still cool air. This is with the heat all the way to 82 and the truck being driven for about 30 minutes. Any ideas?
Old 09-25-2011, 09:51 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
coolant level ok?
Old 09-25-2011, 10:16 PM
EricR's Avatar
Originally Posted by chris015
coolant level ok?
Ooh good point, I havent checked yet. Ill be sure to do that first thing in the morning and let you know.
Old 09-25-2011, 11:41 PM
Tommy G's Avatar
Tommy G is on a distinguished road
Heater core plugged? Blend door actuator bad or stuck?
Old 09-26-2011, 03:39 AM
BlaziNator's Avatar
BlaziNator is on a distinguished road
Could be a vacuum leak in the blend ****. I had the same problem with my selector switch. Stick your head up to the actual **** and see if you hear a hissing. Mine had a bad seal. I also found that if I floored it, it drew enough vacuum temporarily and kicked it where I wanted until I replaced it.
Old 09-26-2011, 10:57 PM
Tommy G's Avatar
Had both problems. Plugged heater core caused the exact problem described by the OP-little if any heat. After flushing the core and the rest of the coolant, back to normal hot heat.
Also had a bad HVAC vacuum switch - it would make a hissing sound and was slow to switch between defrost,vent,floor,etc. Surprisingly a new replacement switch was not available, so I got one from a junkyard.
Maybe I wasn't using the correct terminology? Isn't the blend door electrically operated by the HVAC temp switch?
Old 10-01-2011, 09:57 AM
EricR's Avatar
Thanks guys, turns out the heater core was plugged. Had to have it back flushed but 84 bucks and I have heat again!
njhc
01-26-2011 08:29 PM
Nemo1991
12-09-2010 03:02 PM
stevenf
05-24-2008 07:49 PM
skitzobmxr
02-26-2007 11:13 PM
idg4ever
01-22-2007 07:41 PM
Quick Reply: Heat Doesnt Seem To Work
