Heater Blender Door - Blazer Forum - Chevy Blazer Forums
2nd Gen S-series (1995-2005) Tech Discuss 2nd generation s-series (1995-2005) general tech topics here.
Closed Thread
Thread Tools Search this Thread
Old 03-12-2007, 09:14 PM
bm4183 is an unknown quantity at this point
Default Heater Blender Door
I think my heater blender door is broken or not working properly. Whenever I turn the key on it starts to open and then it shuts and it keeps doing this over and over. The air temp goes from hot to cold. I tried another temperature control module and that didn't fix it. I believe the blender door is operated by an electric actuator. Is there any way to check this? Is this a common problem? Do I have to remove the dash to get to it?
FYI - It has the computer climate control.
Old 03-13-2007, 03:02 AM
Default RE: Heater Blender Door
I believe that it is behind the glovebox. The glovebox rotates down and forward and that lets you see behind it...
Old 03-13-2007, 04:07 AM
That's the problem, when I pull the glove box down, I can't see the actuator. I do see the vacuum controlled actuator that controls whether the air goes to the dash vents or the floor vents and it is working properly. It looks like the electric actuator that controls the blender door is on top of the heater core box and it is hard to see or get to. I guess I'll have to remove the dash to get to it unless someone can tell me another way to get to it or test it.....
Thanks.
Old 03-13-2007, 04:19 AM
Here is a photo of the location of the valve you are talking about. It is like you said but i don't think that you will need to tear the dash out. If you can work by "braille" you might get a small metric wrench in there to pull out the valve/sensor...
[IMG]local://upfiles/1127/5F0EC82A355E42F7A722D80B61C2C1E9.gif[/IMG]
(1) Air Temperature Valve Sensor and Motor
(2) Air Temperature Valve Sensor and Motor Connector
(3) Splice Pack SP200
(4) HVAC Solenoid Assembly Connector
(5) HVAC Solenoid Assembly
Old 03-16-2008, 09:52 PM
trwolf is an unknown quantity at this point
I'm having the same problem... Anyone have troubleshooting tips for the heat blender door motor or controls?
*Combining consecutive posts.
Oh and Thanks 20Blazer00
for the great drawing... It helped me identify the part I was looking for. But how do I test/troubleshoot further without completely opening the dash.
Speaking of opening the dash. Any tips on doing that on a 99 with auto air?
Old 03-16-2008, 10:04 PM
Closed Thread
Thread Thread Starter Forum Replies Last Post
Panel Door and Heater-Defrost Door Actuators.. Skitzoape 1st Gen S-series (1983-1994) Tech 0 01-04-2014 12:06 PM
Electric Blender Actuator fondo 2nd Gen S-series (1995-2005) Tech 7 02-26-2013 02:27 PM
Heater blend door hcii 2nd Gen S-series (1995-2005) Tech 0 11-27-2010 06:53 AM
Please Help! a/c calibration for heater door Scooterewski 2nd Gen S-series (1995-2005) Tech 4 05-17-2008 03:53 PM
heater blend door acuator whiskey24 2nd Gen S-series (1995-2005) Tech 1 10-26-2007 09:29 PM
Tags
2000, 2007, 99, actuator, blazer, blender, blendor, chevy, door, drawing, honda, located, motor, odyssey, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
