Heater Core Replacement.......97 Blazer
Old 05-17-2007, 07:11 AM
brinriha's Avatar
brinriha is an unknown quantity at this point
Default Heater Core Replacement.......97 Blazer
Well the heater core finally went. I have to replace it now. Does anyone have a write up for it, or is the haynes manual pretty good on replacing it? Its a 97 Blazer 4X4 4.3. Just replaced the intake gaskets. Thanks and hope to hear from someone.
Brian
Old 05-17-2007, 07:20 AM
Default RE: Heater Core Replacement.......97 Blazer
Here ya go:
heater core
That has the procedure, but is alittle lite on pictures. Also has some good advice.
Old 05-18-2007, 06:30 AM
brinriha's Avatar
Ok well I got it out. The parts store delivered the wrong one, otherwise I would have it at least in (the heater core) Hopefully the dash goes in smooth like it came out. Lots of stuff to disconnect. But other than that. Not to terribly bad. Thanks swartllk for the write up. Really didn't use it too much and the Haynes manual is very very vague on describing. The don't say you need to disconnect some vacuum lines amongst other things or I just read over it on accident. You can click here for pics. http://s101.photobucket.com/albums/m...r/97%20Blazer/
Brian
zantam06
08-04-2012 02:00 AM
johnb
12-03-2010 10:26 AM
Rodzilla
11-22-2010 07:35 PM
jimhens82
09-06-2010 07:13 PM
Morlais
12-22-2009 10:23 AM
Quick Reply: Heater Core Replacement.......97 Blazer
